Calculate difference between values in the same column
- 6 years ago
Try Earlier function
https://community.powerbi.com/t5/Desktop/Explanation-of-the-EARLIER-formula/td-p/529469
Appreciate your Kudos. In case, this is the solution you are looking for, mark it as the Solution. In case it does not help, please provide additional information and mark me with @
Thanks.
My Recent Blog - https://community.powerbi.com/t5/Community-Blog/Comparing-Data-Across-Date-Ranges/ba-p/823601 - 6 years ago
Hi Resh,
You could try to use below measure to get difference between each month.
trend = SUM('Table (2)'[Value])-CALCULATE(SUM('Table (2)'[Value]), FILTER(ALLEXCEPT('Table (2)','Table (2)'[Project]),MONTH('Table (2)'[Date])=MONTH(MIN('Table (2)'[Date]))-1))Best Regards,
Zoe ZhiIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Is this data in single column or split across columns.
IF it is in single column you need to split Column
if different columsn you can create measure and then make the visualisation. Please take the Screenshot of your data and show here to give more clear answer
