FredPereira
6 years agoFrequent Visitor
Calculate difference between the first two dates in rows using M
Hi, First of all, thanks for your time! Your help is VERY appreciated. Let's say I have the following table: Case Number Email Date/Time IsIncoming 0000000 1-1-20 14:00 FALSE ...
- 6 years ago
Hi FredPereira ,
You could refer to below M code to see whether it work or not.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMoAAJR0lQ11DXSMDBUMTKzDXzdEn2FUpVidayRACwEqMkJWEBIViqjDGbogRBICVmGA1BFmFKXZDjCEArMQMqyHIKswJG2JB0BBLLIbEAgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [#"Case Number" = _t, #"Email Date/Time" = _t, IsIncoming = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Case Number", type text}, {"Email Date/Time", type datetime}, {"IsIncoming", type logical}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Case Number", "IsIncoming"}, {{"min", each List.Min([#"Email Date/Time"]), type datetime}}), #"Pivoted Column" = Table.Pivot(Table.TransformColumnTypes(#"Grouped Rows", {{"IsIncoming", type text}}, "en-US"), List.Distinct(Table.TransformColumnTypes(#"Grouped Rows", {{"IsIncoming", type text}}, "en-US")[IsIncoming]), "IsIncoming", "min"), #"Added Custom" = Table.AddColumn(#"Pivoted Column", "Custom", each [false]-[true]), #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"false", "true"}), #"Merged Queries" = Table.NestedJoin(#"Removed Columns", {"Case Number"}, #"Pivoted Column", {"Case Number"}, "Removed Columns", JoinKind.LeftOuter), #"Expanded Removed Columns" = Table.ExpandTableColumn(#"Merged Queries", "Removed Columns", {"false", "true"}, {"false", "true"}) in #"Expanded Removed Columns"Or
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMoAAJR0lQ11DXSMDBUMTKzDXzdEn2FUpVidayRACwEqMkJWEBIViqjDGbogRBICVmGA1BFmFKXZDjCEArMQMqyHIKswJG2JB0BBLLIbEAgA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [#"Case Number" = _t, #"Email Date/Time" = _t, IsIncoming = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Case Number", type text}, {"Email Date/Time", type datetime}, {"IsIncoming", type logical}}), #"Grouped Rows" = Table.Group(#"Changed Type", {"Case Number", "IsIncoming"}, {{"min", each List.Min([#"Email Date/Time"]), type datetime}}), #"Pivoted Column" = Table.Pivot(Table.TransformColumnTypes(#"Grouped Rows", {{"IsIncoming", type text}}, "en-US"), List.Distinct(Table.TransformColumnTypes(#"Grouped Rows", {{"IsIncoming", type text}}, "en-US")[IsIncoming]), "IsIncoming", "min"), #"Added Custom" = Table.AddColumn(#"Pivoted Column", "Custom", each Duration.Days(Duration.From([false]-[true]))), #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"false", "true"}), #"Merged Queries" = Table.NestedJoin(#"Removed Columns", {"Case Number"}, #"Changed Type", {"Case Number"}, "Removed Columns", JoinKind.LeftOuter), #"Expanded Removed Columns1" = Table.ExpandTableColumn(#"Merged Queries", "Removed Columns", {"Email Date/Time", "IsIncoming"}, {"Email Date/Time", "IsIncoming"}), #"Replaced Value" = Table.ReplaceValue(#"Expanded Removed Columns1",null,0,Replacer.ReplaceValue,{"Custom"}), #"Added Custom1" = Table.AddColumn(#"Replaced Value", "Custom.1", each if [Custom] <= 1 then "Y" else "N") in #"Added Custom1"Best Regards,
Zoe ZhiIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Greg_Deckler
6 years agoSeems like you could do a MINX for Date/Time on a filter of IsIncoming TRUE to get your first arrival date/time. Then a MINX for Date/Time on a filter of IsIncoming FALSE.
FredPereira
MINX in PowerQuery?
