Build Heat Map using x and y coordinates
Hello All,
How can we plot or use x and y coordinates instead of longitude and latitude in the heat map?
Even a formula to convert x and y into longitude and latitude.
Please let me know if this is possible.
Thank you, everyone!!
- lbendlin
For small cardinalty of x and y:
- Use a matrix visual
- put your x data in the columns
- put your y data in the rows
- put your measure into the values
- now use conditional formatting based on the measure. Use the same condition for font color and background color.
Or use a scatter plot visual.
- AnonymousNot applicable
That won't help.
I am looking forward to plotting my coordinates on the Heat Map, not onto the scatter plot visual.
Thanks for responding.
Hi, Is it possible to plot the x and y coordinates on the heat map instead of longitude and latitude coordinates?
For example,
x-coordinates :454014 y-coordinates :4944234
Thank you
- v-eachen-msft
Hi Anonymous ,
You could contact with the author of Heat Map to add this feature. Here is the link:
https://weiweicui.github.io/PowerBI-Heatmap/ - Fortunato_INBFrequent VisitorHello Anonymous,I solved this issue by creating a function that transforms geographic coordinates (lat / long) into plane coordinates (UTM) in Power Query using the M language.
Step 1 (Create the role):
- Copy the code below.
- Go to Power Query in the "Home" tab and click "Enter Data" and click "OK".
- Click on the table that was just created, and click on "Advanced Editor".
- Paste the code and click "Done".
Step 2 (Invoke function):
- Select the table you want to transform the coordinates.
- In the "add column" tab, click "Invoke Custom Function".
- Select the function you created and inform the columns that are the coordinates UTM (north and east), Hemisphere (N for north and S for South), Central Meridian and click "OK".
Code (M language):let /*Fórmula para converter coordenadas UTM para Geográficas Desenvolvido por: José Carlos Fortunato - [email protected]*/ UtmLatLong = (UTMeste as number,UTMnorte as number,Hemisferio as text,MeridianoCentral as number) => let long0 = MeridianoCentral, Hem = Hemisferio, TextHem = Text.Upper(Hem), a = 6378137.0000, b = 6356752.3141, x = 500000 - UTMeste, y = UTMnorte, y1 = if TextHem = "S" or TextHem = "SOUTH" or TextHem = "SUL" then 10000000 - y else y, M = y1 / 0.9996, e = Number.Sqrt(1 - Number.Power(b,2) / Number.Power(a,2)), mu = M / (a * (1 - Number.Power(e,2) / 4 - 3 * Number.Power(e,4) / 64 - 5 * Number.Power(e,6) / 256)), e1 = (1 - Number.Power((1 - Number.Power(e,2)),(1 / 2))) / (1 + Number.Power((1 - Number.Power(e,2)),(1 / 2))), j1 = (3 * e1 / 2 - 27 * Number.Power(e1,3) / 32), j2 = (21 * Number.Power(e1,2) / 16 - 55 * Number.Power(e1,4) / 32), j3 = (151 * Number.Power(e1,3) / 96), j4 = (1097 * Number.Power(e1,4) / 512), fp = mu + j1 * Number.Sin(2 * mu) + j2 * Number.Sin(4 * mu) + j3 * Number.Sin(6 * mu) + j4 * Number.Sin(8 * mu), e2 = Number.Power(e,2) / (1 - Number.Power(e,2)), c1 = e2 * Number.Power((Number.Cos(fp)),2), t1 = Number.Power(((Number.Sin(fp)) / (Number.Cos(fp))),2), r1 = a * (1 - Number.Power(e,2)) / Number.Power((1 - Number.Power(e,2) * Number.Power((Number.Sin(fp)),2)),(3 / 2)), n1 = a / Number.Power((1 - Number.Power(e,2) * Number.Power((Number.Sin(fp)),2)),(1 / 2)), d = x / (n1 * 0.9996), q1 = n1 * ((Number.Sin(fp)) / (Number.Cos(fp))) / r1, q2 = Number.Power(d,2) / 2, q3 = (5 + 3 * t1 + 10 * c1 - 4 * Number.Power(c1,2) - 9 * e2) * Number.Power(d,4) / 24, q4 = (61 + 90 * t1 + 298 * c1 + 45 * Number.Power(t1,2) - 3 * Number.Power(c1,2) - 252 * e2) * Number.Power(d,6) / 720, latrad = fp - q1 * (q2 - q3 + q4), lat = if TextHem = "S" or TextHem = "SOUTH" or TextHem = "SUL" then -1 * (latrad * (180 / Number.PI)) else (latrad * (180 / Number.PI)), q5 = d, q6 = (1 + 2 * t1 + c1) * Number.Power(d,3) / 6, q7 = (5 - 2 * c1 + 28 * t1 - 3 * Number.Power(c1,2) + 8 * e2 + 24 * Number.Power(t1,2)) * Number.Power(d,5) / 120, longrad1 = (q5 - q6 + q7) / (Number.Cos(fp)), longrad2 = longrad1 * (180 / Number.PI), longi = if long0 < 0 then long0 - longrad2 else long0 + longrad2 in Table.FromRecords({[latitude = lat,longitude = longi]}) //UtmLat = Table.AddColumn(UtmLatLong, "latitude", each List.First(UtmLatLong([este],[norte], "SUL", -45),1),type number), //UtmLong = Table.AddColumn(UtmLat, "longitude", each List.Last(UtmLatLong([este],[norte], "SUL", -45),1),type number) in UtmLatLong
Hope this helps!- AnonymousNot applicable
Fortunato_INB thank you for replying. I followed the instruction and during Step 2, I didn't get any output back after Apply and close. All we get is [Table] in our output row.
Whereas, we were looking for long and lag fields.
However, I'm only able to transform just one row by manually entering the value before invoking the function (before STEP 2). We are looking for a solution when we refresh the data table the x and y coordinations are automatically transformed into long and lat.
Would you be able to suggest a solution or correct me?
Thank you
