joshua1990's avatar
joshua1990
Icon for Post Prodigy rankPost Prodigy
4 years ago
Same Report for Web and Mobile individually
Hello all,
I have an app which contains numerous complex tabs and matrix visuals. Often with 2-3 levels.
Is there a way to redesign these reports exclusively for Power BI Mobile? So once for web and once for mobile?
In the past it was always the same visuals and details that could be used, right?
Is there a workaround in the meantime?
  • Hi joshua1990
    As for today there is no way to add a different visual that will be available only in mobile .
    We did add the option to format the visual exclusively for mobile, but this will not solve your issue you have with the tables and matrix.
    We are aware of this constrain and we are thinking on a way to overcome and solve it.
    Meanwhile the current workaround for such cases it to create the tab/matrix that fit mobile and hide it beaned the visual in the web.
    You can also try the new field parameters feature bookmarks (for short/long version of the table)
    Michal
1 Reply
  • Hi joshua1990
    Michal
