Mobile layout zoom problem
I have a problem with report layout on mobile devices, when I run Power BI mobile app (both Android and iOS versions).
The maps are very glitchy when zoom in. When I try zoom in, it zooms but the screen jumps to another part of the report and it shows another chart.
Hey AGarbuzyuk ,
Thanks for reporting this issue. We are aware of issues with pinch2zoom and working on releasing a fix. We expect it to be available by early February. This is a service side fix, therefore there is no need to upgrade the app in order to enjoy it.
Thanks, Maya
- mshenhavPower BI Team
Hey AGarbuzyuk ,
Thanks, Maya
- AnonymousNot applicable
Hi AGarbuzyuk ,
As a workaround, you can expand to focus mode and then zoom.
Stephen Tao
