insert/update/delete operation need to perform on SQL table by using power apps
Hey @Anshenterprices
for that, you can use the patch function to insert the record into the database.
updateif and patch function is used to update the record from the database and you want to delete the record from the database for that you can use the remove function.
Update function updates the entire record in a database.
UpdateIf and Patch functions update only specific columns. Update and UpdateIf both return table as a modified data source.
for inserting the record into the database:-
Patch(datasourcename, Defaults(datasourcename), {DepartmentName:drpDrptname.selected.value, CollegeName:drpclgname.selected.value, City:drpCityName.selected.value, Revenue:Value(500), Date:Today()});
and if you want to remove the record from the gallery then use the delete icon and then onselect property
OnSelect :- Remove(datasourcename, ThisItem)
I hope this is helpful for you.
Thank You!
