cathoms
Responsive Resident
5 years agoVisualization to compare two values for same person, from same row
I have a dataset where each provider has a separate row with the following columns (plus others): NPI (id/key) Total Visits 99212 visits 99213 visits 99214 visits 99215 visits 99212 peer 9...
- 5 years ago
So my alternative solution was to simply create four separate visuals per provider - one for each code. I used Bullet Chart by OKVIZ. Here is the end result:
cathoms
Responsive Resident
5 years agoI figured out an alternative using multiple visuals.
