Using web services from Power BI
Hi Msheikh,
You can connect to a Web page, and import its data into Power BI Desktop, to use in your visuals and in your data models. See Connect to a Web page from Power BI Desktop and Tutorial: Importing and analyzing data from a Web Page using Power BI Desktop
Regards
For example, "Dropbox" can not read file
Do not resolve my issue
- v-ljerr-msft9 years ago
Hi Msheikh,
What do you mean about "Dropbox cannot read file"? Do you want to import files from Dropbox into Power BI Desktop, then built reports with that files? Could you be more precisely with your requirement in this case?:smileyhappy:
Regards
- Msheikh9 years agoRegular Visitor
I want my data import files In this way , For example, Dropbox or Portal or ...
Do you want to import files from Dropbox into Power BI Desktop, then built reports with that files? YES and Auto refresh If the updated file.
Hi Msheikh,
Currently, it is not possible to import data from Dropbox into Power BI Desktop directly. You can vote the idea here.
In addition, I also found a similar thread here, could you go and check if it helps.:smileyhappy:
Regards
