AlexisCohen88K's avatar
AlexisCohen88K
5 years ago
Using variables in custom column Power M
I'm trying to build a string whose parts will depend on a column value.
In order to avoid writing a if statement for each possibility, I tried to write 3 if block that assign the desired value to a variable.
Final stage is to combine variables value to get my final string (like I would do in VBA)
I got an error on the second if block (Token Eof expected).
Below is the code (written in a custom column dial box):
if [Status__c]="For Sale" or [Status__c]="FS (Unverified)" then variable_status="For sale"
else if [Status__c]="FS (Deal Pending)" or [Status__c]="FS (Pndg - Unv)" then variable_status="Deal Pending"
else if [Status__c]="For Lease" then variable_status="For Lease"
else if [Status__c]="Not for Sale" then variable_status="Not for Sale"
else variable_status="Unknown"
if [Ac Deal.Name]<>null then variable_inventory="88K " & [Airplane Caracter] & " " else variable_inventory=null
if [is_off_market__c]=true then variable_market="(Off-Market)" else variable_market=null
variable_inventory & variable_status & variable_market
The result expected in this last line that concatenate all the variables text into one string.
Would you have any idea on how to achieve this without creating 3 different columns or getting things too complex?
I already got +100 columns...
Thank you for your time!
  • AlexisCohen88K you can write a function and let it return the concatenated text.
    (status_c, acdeal_name, airplane_caracter, is_off_market__c)=>
    var1 = if status_c="For Sale" or status_c="FS (Unverified)" then  "For sale"
    else if status_c="FS (Deal Pending)" or status_c="FS (Pndg - Unv)" then  "Deal Pending"
    else if status_c="For Lease" then  "For Lease"
    else if status_c="Not for Sale" then  "Not for Sale"
    else  "Unknown",
    var2 = if [acdeal_name<>null then "88K " & airplane_caracter & " " else null,
    var3 = if is_off_market__c=true then "(Off-Market)" else null
    var1 & var2 & va3
    now add a new column in your main table and call this function and pass columns as parameters
    Check my latest blog post Year-2020, Pandemic, Power BI and Beyond to get a summary of my favourite Power BI feature releases in 2020
    I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
    ⚡Visit us at https://perytus.com, your one-stop-shop for Power BI-related projects/training/consultancy.⚡
    else  "Unknown",
    var1 & var2 & va3
    • AlexisCohen88K's avatar
      AlexisCohen88K
      Hello parry2k,
      Thank you for your help.
      I just created the following function and invoked in a custom column with variables being my table columns. I have an error on the resulting column :
      "Expression.Error: We cannot convert a value of type Table to type Function.
      Details:
      Value=[Table]
      Type=[Type]"
      Tried several thigs but I could not get any result. Would you have any idea?
      Here is my function :
      = (Status__c, acdeal_name, airplane_caracter, is_off_market__c)=>
          var_status = if Status__c="For Sale" or Status__c="FS (Unverified)" then  "For sale"
          else if Status__c="FS (Deal Pending)" or Status__c="FS (Pndg - Unv)" then  "Deal Pending"
          else if Status__c="For Lease" then  "For Lease"
          else if Status__c="Not for Sale" then  "Not for Sale"
          else  "Unknown",
          var_inventory = if acdeal_name<>null then "88K " & airplane_caracter & " " else null,
          var_offmarket = if is_off_market__c=true then "(Off-Market)" else null
      var_status & var_inventory & var_offmarket
      Thank you again
    • Syndicate_Admin's avatar
      Icon for Administrator rankAdministrator
      Hello
      I have been looking for this solution for a long time, thanks for sharing it, I have managed to load the variables.
