Using SQL declared variables into Power BI
- 1 year ago
Thankyou, MohamedFowzan1, CPCARDOSO, kushanNa for your responses.
Hi cheid_4838,Based on my understanding, in Import mode parameters can only be applied during refresh and cannot be bound to slicers. Consequently, the Bind to Parameter option does not appear. In DirectQuery mode, dynamic M parameters are supported; however, the current SQL query contains unsupported constructs such as correlated subqueries and ORDER BY in subqueries. These constructs break query folding, preventing DirectQuery from executing the query in its present form.
If you remain in Import mode, parameters will work only at refresh time and will not be dynamic. If you require slicer driven parameters, switch to DirectQuery and simplify the SQL by using a database view or stored procedure that accepts parameters. This will enable query folding and allow binding slicers to parameters.
Additionally, please refer to the following links:
Value.NativeQuery - PowerQuery M | Microsoft Learn
Dynamic M query parameters in Power BI Desktop - Power BI | Microsoft LearnWe hope this information helps to resolve the issue. Should you have any further queries, please feel free to contact the Microsoft Fabric community.
Hi cheid_4838
I have tried to reproduce your scenarios on my local machine and got an error related to an ORDER BY clause. So, I asked some AI tools to rewrite the query suitable for Power BI, and they gave me this query. It looks like they just removed the ORDER BY clause, but anyway, I have copied the full code here.
SELECT
-- Order Information
ih.ord_hdrnumber AS OrderNum,
ih.ivh_deliverydate AS Delivery,
-- Origin Information
orig.cty_name AS Origin,
orig.cty_state AS OSt,
orig.cty_region2 AS OReg,
-- Destination Information (with split flag logic)
ISNULL(
CASE
WHEN l.lgh_split_flag = 'N'
THEN dest.cty_name
ELSE legdest.cty_name
END,
'Temple'
) AS Dest,
ISNULL(
CASE
THEN dest.cty_state
ELSE legdest.cty_state
END,
'TX'
) AS DSt,
ISNULL(
CASE
THEN dest.cty_region2
ELSE legdest.cty_region2
END,
'TX-TEM'
) AS DReg,
-- Split Flag
l.lgh_split_flag AS SplitFlag,
-- MT Miles Original (capped at 200)
CASE
WHEN ISNULL(
(SELECT SUM(ISNULL(stp_lgh_mileage, 0))
FROM stops s1 (NOLOCK)
WHERE ih.ord_hdrnumber = s1.ord_hdrnumber
AND s1.stp_loadstatus IN ('MT', 'BT')), 0
) > 200
THEN 200
ELSE ISNULL(
END AS MTMilesOG,
-- MT Miles (capped at 100)
CASE
WHEN ISNULL(
) > 100
THEN 100
ELSE ISNULL(
END AS MTMiles,
-- Rate from STATEM invoices
(SELECT TOP 1 ih2.ivh_rate
FROM invoiceheader ih2 (NOLOCK)
WHERE ih2.ivh_billto = 'STATEM'
AND ih2.ivh_deliverydate >= '08-01-2025'
AND ih2.ivh_deliverydate < '08-20-2025'
AND ih2.ivh_rate > 1.2
AND ih2.ivh_rate < 2.5
ORDER BY CAST(ih2.ivh_deliverydate AS DATE) DESC
) AS Rate,
-- Billing MT Miles calculation
CASE
WHEN ISNULL(
) > 100
THEN 100
ELSE ISNULL(
END *
) AS BillMTMi,
-- FSC Rate
(SELECT AVG(id.ivd_rate)
FROM invoicedetail id (NOLOCK)
INNER JOIN invoiceheader ih3 (NOLOCK) ON ih3.ivh_hdrnumber = id.ivh_hdrnumber
WHERE id.cht_itemcode LIKE 'FSCMI%'
AND ih3.ivh_billto = 'STATEM'
AND ih3.ivh_deliverydate >= '08-01-2025'
AND ih3.ivh_deliverydate < '08-20-2025'
) AS FSCRate,
-- Billing MT FSC calculation
CASE
WHEN ISNULL(
) > 100
THEN 100
ELSE ISNULL(
END *
) AS BillMTFSC,
-- Billing Information
ih.ivh_totalcharge AS BHGrossAmt,
-- Stop Information
(SELECT MAX(stp_mfh_sequence)
FROM stops s (NOLOCK)
WHERE s.mov_number = ih.mov_number
) AS LastStopID,
ISNULL(s.stp_lgh_mileage, 25) AS LastStopMiles,
-- Revenue Calculations
0.75 AS RPM,
0.75 * s.stp_lgh_mileage AS ReduceBHAmount,
CASE
WHEN orig.cty_name = 'Brownwood'
AND dest.cty_region2 = 'TX-DAL'
THEN ih.ivh_totalcharge
ELSE ih.ivh_totalcharge - (0.75 * ISNULL(s.stp_lgh_mileage, 25))
END AS BHTotal,
CASE
THEN ih.ivh_totalcharge * -1
ELSE ((ih.ivh_totalcharge - (0.75 * ISNULL(s.stp_lgh_mileage, 25))) * 0.8) * -1
END AS BHCredit,
ih.ivh_billto
FROM invoiceheader ih (NOLOCK)
-- Join with origin city
INNER JOIN city orig (NOLOCK)
ON orig.cty_code = ih.ivh_origincity
-- Join with destination city
INNER JOIN city dest (NOLOCK)
ON dest.cty_code = ih.ivh_destcity
-- Optional join with leg header
LEFT JOIN legheader l (NOLOCK)
ON l.ord_hdrnumber = ih.ord_hdrnumber
-- Optional join with leg destination
LEFT JOIN city legdest (NOLOCK)
ON legdest.cty_code = l.lgh_endcity
-- Optional join with last stop
LEFT JOIN stops s (NOLOCK)
ON s.mov_number = ih.mov_number
AND s.stp_mfh_sequence = (
WHERE
-- Filter conditions
ih.ivh_revtype3 = 'SC-BH'
AND ih.ivh_billto NOT LIKE 'STATEM%'
AND ih.ivh_deliverydate >= '08-01-2025'
AND ih.ivh_deliverydate < '08-20-2025'
AND (l.lgh_split_flag IN ('N', 'S') OR l.lgh_split_flag IS NULL)
AND ih.ivh_invoicenumber = (
SELECT MAX(ih2.ivh_invoicenumber)
WHERE ih2.ord_hdrnumber = ih.ord_hdrnumber
AND RIGHT(ivh_invoicenumber, 1) <> 'B'
-- ORDER BY MTMilesOG DESC -- Removed for Power BI compatibility
It looks like just removing the ORDER BY clause makes DirectQuery mode work.
