4 years agoNot applicable
Using 'SELECTEDVALUE' inside 'CALCULATE'
I am trying to use 'SELECTEDVALUE' inside the 'CALCULATE' function and Power BI is showing an error: "A function 'SELECTEDVALUE' has been used in a True/False expression that is used as a table filte...
- Anonymous4 years ago
Thanks for your reply amitchandak .
I didn't know that I could use another 'FILTER' inside CALCULATE. Your measure had some unexpected behavior in the chart. I could solve the problem using the following measure:
Measure_01 =CALCULATE(SUM(Meta_Comp_Alim[Meta_Alim_Diaria]),Meta_Comp_Alim[COD_DEP] = VALUES(Tab_Auxilar_COI[Cod_Item]),FILTER(ALL(Date_Table),Date_Table[Date_Column] <= MAX(Date_Table[Date_Column])))
4 years agoAnonymous , seems strange
try like
Measure_01 =
CALCULATE(
filetr(Meta_Comp_Alim,Meta_Comp_Alim[COD_DEP] = SELECTEDVALUE(Tab_Auxilar_COI[Cod_Item])),
FILTER(
ALL(Date_Table),
If this does not help
Can you share a sample pbix after removing sensitive data.
