Using "Reference" in Query Editor does not prevent loading base query multiple times
- 8 years ago
Hi Sokon,
I'm afraid that's how the Power Query works in Power BI. How about the Direct Query mode?
Dale
Hi Sokon,
Dale
- Sokon8 years ago
Advocate V
Anonymous: You seem to have the same expection like I had. But, no, it's true: PQ will NOT load the base query ONCE, but as many times as there are queries that reference it +1 (itself). You can verify that fact by setting up a base query and a query that refernces it using an SQL Server database and then watch the Activity Monitor during dataset refresh: You will see TWO identical queries being run. Additionally the loading speed will plummet. It's horrible...
v-jiascu-msft: Thanks for the confirmation that this is "as designed". I had hoped that there will be a M command that perhaps allows caching a query that I don't know. However there seems to be none and I have to look for a way around - Direct Query will certainly be a way to consider.
Edit
I found a very detailed explanation here, that helped a lot.
There IS a command Table.Buffer to cache results and that could help to solve the problem at least in some cases.
