norbi's avatar
norbi
8 years ago
Using Ratios between two tables for output depending on Filter
I would truly appreciate some assistance with a challenge I have been struggling with in Power BI. I would like to get the Customer_Number ratios in Table_1 to split the Year_1, Year_2 and Year_3 numbers. Here is the example:
Table_1
Shop
Customer_Type
Customer_Numbers
shop_1
Customer_Type_1
10
shop_1
Customer_Type_2
20
shop_1
Customer_Type_3
50
shop_2
Customer_Type_1
8
shop_2
Customer_Type_2
6
shop_2
Customer_Type_3
50
shop_3
Customer_Type_1
30
shop_3
Customer_Type_2
150
shop_3
Customer_Type_3
200
In Table_1 I have three different Shop's with three different Customer_Types split in numbers.
Table_2
Customer_Type
Year_1
Year_2
Year_3
Customer_Type_1
100
200
400
Customer_Type_2
150
250
500
Customer_Type_3
170
300
370
In Table_2 are the Year_1, Year_2 and Year_3 desired numbers to achieve.
Power BI Output
Shop
Customer_Type
Target_1
Target_2
Target_3
shop_1
Customer_Type_1
                               20.83
                            41.67
                            83.33
shop_1
Customer_Type_2
                               17.05
                            28.41
                            56.82
shop_1
Customer_Type_3
                               28.33
                            50.00
                            61.67
shop_2
Customer_Type_1
                               16.67
                            33.33
                            66.67
shop_2
Customer_Type_2
                                 5.11
                              8.52
                            17.05
shop_2
Customer_Type_3
                               28.33
                            50.00
                            61.67
shop_3
Customer_Type_1
                               62.50
                         125.00
                         250.00
shop_3
Customer_Type_2
                            127.84
                         213.07
                         426.14
shop_3
Customer_Type_3
                            113.33
                         200.00
                         246.67
The Targets in the Power BI Output table should be derived from Table_1 and Table_2 in Power BI. However it should also automatically change this as the filters change e.g. if I only filter on Customer_Type_1 & 2 or Shop_1 & 3 the split should be calculated to achieve the Target_1, Target_2 and Target_3.
Any assistance will be truly appreciated.
    • Zubair_Muhammad's avatar
      Zubair_Muhammad
      norbi
      Here are the Steps
      1) Create the relationship between two table using Customer_Type
      2) Add the Following Calculated Column in Table 1 to get the %ages on which Targets will be determined
      %_age =
      DIVIDE (
          Table1[Customer_Numbers],
              SUM ( Table1[Customer_Numbers] ),
              ALLEXCEPT ( Table1, Table1[Customer_Type] )
      3) Add the Calculated Columns for Targets
      Target 1 =
      RELATED ( Table2[Year_1] ) * Table1[%_age]
       and so on for Targets 2 and 3
      • norbi's avatar
        norbi
        Zubair_Muhammad
        Thank you very much for the feedback and information. The calculation works if you use all e.g. Segments and Shops, however if you would like to see the impact if you take away one Shop or Segment the number remain and do not update for the once selected only. SO what I would like to achieve is to take the Year_1 Numbers and they need to total to the selection made, also if only one or two Shops or segments are selected.
