MarcusR1
Helper II
3 years agoUsing Python Regex to look for values in column
I'm trying to add a column called ofInterest select postcodes that match RG, OX & SA, the column would contain a 1 if the match is found, or 0 if not found. My code is: import pandas as pd impo...
MarcusR1
Helper II
3 years agoHi Neeko, unfortunately your solution doesn't work as REGEX becasue I need to look for any of the letters follwoed by a number (regexz /[SRO][AGX][0-9]/) but your suggestion doesn't do that.
all the best, Marcus
3 years agoNot applicable
Hi MarcusR1 ,
I'm sorry I can't understand your needs, please provide some sample data in your tables (exclude sensitive data) with Text format and your expected result with backend logic and special examples. It is better if you can share a simplified pbix file. Thank you.
Neeko Tang
