Using Python Regex to look for values in column
Hi MarcusR1 ,
Has your problem been solved?If the problem has been solved you can mark the reply for the standard answer to help the other members find it more quickly. If not, please point it out.
Neeko Tang
- MarcusR13 years agoHelper II
Hi Neeko, unfortunately your solution doesn't work as REGEX becasue I need to look for any of the letters follwoed by a number (regexz /[SRO][AGX][0-9]/) but your suggestion doesn't do that.
all the best, Marcus- Anonymous3 years agoNot applicable
Hi MarcusR1 ,
I'm sorry I can't understand your needs, please provide some sample data in your tables (exclude sensitive data) with Text format and your expected result with backend logic and special examples. It is better if you can share a simplified pbix file. Thank you.
Neeko Tang
