Anonymous's avatar
6 years ago
Using Power BI with output from Forms
I am taking an output from Micrsoft Forms via Excel into Power BI. The output is a survey and that looks like TABLE A) and I need to create a visual like TABLE B)
TABLE A
EventAttendee 1Attendee 2Attendee 3
EVT1GoodPoorAverage
EVT2AveragePoorAverage
EVT3PoorGoodPoor
TABLE B
EventPoorAverageGood
EVT1111
EVT2120
EVT3201
How is this done?
  • Anonymous ,
    In power query, click on [Attendee 1], [Attendee 2] and [Attendee 3], then click Transform-> Unpivot Columns, you will acheve the table as below:
    Then click [Value] and click Pivot Column as below, you will achieve the expected table:
    The result is as below:
    Jimmy Tao
1 Reply
  • v-yuta-msft's avatar
    v-yuta-msft
    Anonymous ,
    Jimmy Tao
