Ebrahim123's avatar
Ebrahim123
6 years ago
Using Power BI for Sage 300 evolution
Hi
I want to use the the sage 300 analytics apps from power bi app source. My data source is a local sql server. When I select all tables in the database on power bi desktop it takes forever to load and eventually says not enough memory. Can someone please assist me on how to go about using the sage 300 analytics app to connect to my company's sql database.
    5 years ago
    Hi Ebrahim123
    Could you tell me if your problem has been solved? If it is, kindly Accept it as the solution. More people will benefit from it. Or you are still confused about it, please provide me with more details about your problem.
    Rico Zhou
    Hi Ebrahim123
    Your data source in local sql server may be huge, you may try to connnect to your data source by direct query.
    Here are some blogs and I hope they could help you solve your problem.
    Blog1: Use DirectQuery in Power BI Desktop
    Blog2: Import Sage 300 Data into the Power BI Service for Visualizations
    Rico Zhou
    Hi Ebrahim123
    Rico Zhou
