Anonymous's avatar
4 years ago
Using power automate to send emails when data values reach threshold
I've been trying to create a flow that happens using power bi data, and continues even after the power bi button has been clicked. I essentially have a table of live data, and I want to be notified if certain values are repeated over a set number of times. This obviously would implement count. My main issue is that I want this to be done live, using direct query, so that as soon as a certain value has a count greater than the threshold I am sent an email. My problem is that the build in power automate visual only activates when the button is clicked, I want this flow to be more scheduled, refreshing every minute or second if possible.
I've tried a lot of work arounds including the do until action, and trying to schedule a flow. The problem with a scheduled flow is it needs a data value to reach a goal, I want to see even after one value reaches a threshold if any others reach that threshold.
      Two questions. First will this work without having powerbi pro? Also I was just trying to test this but am unsure of what to put in the "Query Text" box.
      • lbendlin's avatar
        lbendlin
        Not sure what you mean by "Power BI Pro" - please clarify.
        You put your DAX query in there, as described in the article.  You can use Performance Analyzer to "borrow"  the DAX query that is used for a particular Power BI visual, or you can construct your own.
    Hello I am trying to achive somthing similar. in my run a query agains dataset i output a table with two columns. my question is how to reference the column 2 in the next step .
    when the value is
    • lbendlin's avatar
      lbendlin
      Anonymous please create a new post.
