Using OR function within Text.replace function - Power Query
- Anonymous5 years ago
Hi OsmanEmi
I suggest you to build a replacement table then try my M code. Currently, you will replace all words by the same word "Fact". This way will still work if you want to replace multiple words by different words.
My Sample:
Replacement Table:
Use M Code to add a custom column:
Text.Combine( { [Destination Type], List.Accumulate( List.Numbers(0,Table.RowCount(replacements)), [Destination Name], (state, current) => Text.Replace(state, replacements[Find]{current}, replacements[Replace]{current})) }, " | " )Result is as below.
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Hi OsmanEmi
My Sample:
Replacement Table:
Text.Combine(
[Destination Type],
List.Accumulate(
[Destination Name],
(state, current) =>
Result is as below.
Rico Zhou
