OsmanEmi's avatar
OsmanEmi
5 years ago
Using OR function within Text.replace function - Power Query
Hi, I'm sort of new to power query and while adding a new column I used the below function which works, however I wanted to ask if their was a way to also replace more than one value. = [#"Dest...
    5 years ago
    Hi OsmanEmi
    I suggest you to build a replacement table then try my M code. Currently, you will replace all words by the same word "Fact". This way will still work if you want to replace multiple words by different words.
    My Sample:
    Replacement Table:
    Use M Code to add a custom column:
    Text.Combine(
      [Destination Type],
      List.Accumulate(
        List.Numbers(0,Table.RowCount(replacements)),
        [Destination Name],
        (state, current) =>
        Text.Replace(state, replacements[Find]{current},
        replacements[Replace]{current}))
    Result is as below.
    Rico Zhou
