Using OR function within Text.replace function - Power Query
- Anonymous5 years ago
Hi OsmanEmi
I suggest you to build a replacement table then try my M code. Currently, you will replace all words by the same word "Fact". This way will still work if you want to replace multiple words by different words.
My Sample:
Replacement Table:
Use M Code to add a custom column:
Text.Combine( { [Destination Type], List.Accumulate( List.Numbers(0,Table.RowCount(replacements)), [Destination Name], (state, current) => Text.Replace(state, replacements[Find]{current}, replacements[Replace]{current})) }, " | " )Result is as below.
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Hello there OsmanEmi ! Try this and see if it works for your case:
= [#"DestinationType"] & " | " & Table.ReplaceValue([Your table name], each if Text.Contains([#Destination Name], {"Spend", "App", "Card"} then "Facts" else [Destination Name], Replacer.ReplaceValue, {"Destination Name"})
Alternatively, you can check this thread for a similar solution! Or this one!
Hope this answer solves your problem! If you need any additional help please tag me in your reply.
If my reply provided you with a solution, pleased mark it as a solution ✔️ or give it a kudoe 👍
Thanks!
Best regards,
Gonçalo Geraldes
