5 years agoNot applicable
Using measure with MAX function in a visual
Hi all, I have attached a snippet of how my data is in the image above. Basically I have a calculated "Sales%" measure in a card visual to which I have to apply a filter, which will always dis...
- 5 years ago
Hi Anonymous ,
Is this what you want?
Best regards,
Lionel ChenIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
v-lionel-msft
5 years agoHi Anonymous ,
Best regards,
Lionel Chen
v-lionel-msft Slight modification help needed, instead of using today() in the var syntax, how can I keep it to max of the month in a year. The data provided has its year cycle from June-May, so currently it is the 12th month, hence I need the '1' for 2021-12 month and rest it would be zero, how can I achieve that?
