Using filter pane for more than 1 column
I have the following table with 2 columns ID and Age. I want to create a table visualization as shown below
In this visulization i want to use the same column Age two times, where the 1st time it will show the range 1-14 age and the second 15-30 age. I was able to do this with the help of measures.
This is the measure i used :
I was wondering if this was possible with the filter pane. The filter pane when used, filters get applied to all instances of the same column. Is there a way to apply the filter to only one instance? Please help!
You may add a calculated column and use Matrix visual later.
https://community.powerbi.com/t5/Desktop/Creating-groups-based-on-numbers/m-p/197342#M86817
1 Reply
- v-chuncz-msft
