Using external data in a composite model and using imported data into measures
Hi all,
I have recently switched to a DirectQuery model within my organization and am trying to use it using also custom data (from an excel file), thus creating a mixed (or composite) model.
Doing so, it creates limited relationships between both data sets, meaning I am unable to use the imported data in measures or calculated columns, be it using RELATED(), LOOKUPVALUE() or any other formula I tried.
I have read plenty of online articles explaining why that is so, but I do not understand how i can therefore use this imported data for calculation purposes. Is a composite model only good for visualization? If so, imported models are much more convenient as it is possible to use multiple datasources...
- amitchandak
BrendanCarron , related should work - https://youtu.be/aA4ROG9dg8A
The import model is best. In case of direct query, your source should take care of the need of lookupvalue and related. create a model that does not need a new column
- amitchandak
