7 years agoNot applicable
Use Plotly with Python Script in Power BI
Hello, I'm a deep python user so would like to use it in Power BI. I have tried matplotlib and seaborn library - there are no error to use them as long as I put "plt.show()" in the scripts. Howev...
- 7 years ago
Hi Anonymous ,
I'm afraid that Plotly is not supported in Power BI currenly.
Based on the blog, only the following Python packages (non-Intel MKL) are currently supported for use in your Power BI reports.
- matplotlib
- numpy
- pandas
- scikit-learn
- scipy
- seaborn
- statsmodels
In addition, you could refer to this similar thread which should make sense.
Cherry
stevedep
Memorable Member
4 years agoHi,
You could take a look at this blog post. It describes how to add an interactive Plotly Chart in Power BI. Its quite easy when you follow these steps.
Kind regards,
Steve.
