7 years agoNot applicable
Use Plotly with Python Script in Power BI
Hello, I'm a deep python user so would like to use it in Power BI. I have tried matplotlib and seaborn library - there are no error to use them as long as I put "plt.show()" in the scripts. Howev...
- 7 years ago
Hi Anonymous ,
I'm afraid that Plotly is not supported in Power BI currenly.
Based on the blog, only the following Python packages (non-Intel MKL) are currently supported for use in your Power BI reports.
- matplotlib
- numpy
- pandas
- scikit-learn
- scipy
- seaborn
- statsmodels
In addition, you could refer to this similar thread which should make sense.
Cherry
4 years agoNot applicable
Hi any updates on how to use plotly with Python script in Power BI, I can use it but the visualization come into a browser not into the power bi dashboard.
HamidBee
Power Participant
4 years agoAny luck on plotly and Power BI?
Nop the only way is to do it In R not in python
- HamidBee4 years ago
Power Participant
Just so that I understand correctly. Plotly in Python only works with R?
plotly in Power BI only works with R
