unknown error using Power On to auto refresh
Am using Power On application to trigger more frequent refresh throughout the day.
am getting an error for a particular dataset which is more advanced than I can easily understand what I need to fix
Updating workbook C:\Users\sysadmin\Documents\XXXX_DataSet.pbix failed. Please check additional messages in task history for detailed errors.
Publishing failed Trace: at PQRefresh.Program.ProcessExcelFileInternal(String taskName, String tempFolder, String ExcelFile, Boolean importToSQL, String TargetFolder, String baseURL, String folder, ICredentials cred, String credentialName, String file, String pbixPass, String WorkspaceCollectionName, String WorkspaceId, String SubscriptionId, String ResourceGroup, String AccessKey, IEnumerable`1 connections, String WorkspaceName)
Does anyone by any chance can help?
- AnonymousNot applicable
Hi majdkaid22,Do you use Power Update to refresh your dataset? If so, Power Update is a third party tool, about Power update issues, please post the questions in the Power Update forum to get dedicated support.
Lydia Zhang- majdkaid22
Helper V
appreciated Anonymous I didn't know that forum exist.
Cheers,
Majd
