perpor
Helper V
8 years agoTreemap - help - order with two values is possible?
I do not know if it is possible with the current version to create a treemap with two levels of values: I would like a graph where the most external rectangles are sorted by an index1, and the mo...
perpor
Helper V
8 years agoI mean there are currently two datasets, one for the top and one for the level
lower ones that contain the data, index1 in the first and index2 in the second,
even if the data type is the same, for index1 and index2, for example as sales,
values that are indexes anc can not sum up.
I would like to get this type of graph without having to restructure existing datasets
creating for example a unique index, which I think would solve the problem ...
8 years agoNot applicable
Hi perpor,
Can you please provide some sample data? I will try it if possible to achieve this.
Xiaoxin Sheng
