Total measure is wrong using variable with distinctcount and filter
Im using simple DAX which use Variable to store calculation then return distinctcount with filter using the variable.
But the total shows only the distinctcount correct value which 5. But it should show 4 after filter method. I dont know what part is wrong. Please see my DAX and table below. Thanks so much for the help.
| IM Customer Code | Sum T0 Value | Buying Customer |
| 1 | 150 | 0 |
| 2 | 300 | 1 |
| 3 | 400 | 1 |
| 4 | 500 | 1 |
| 5 | 600 | 1 |
| Total | 1950 | 5 |
- amitchandak
isyammil , Try like
Buying Customer =
var x = CALCULATE(SUM('combineSales'[Value]),PARALLELPERIOD(LASTDATE('Calendar'[Date]),0,MONTH))
CALCULATE(DISTINCTCOUNT(combineSales[IM Customer Code]),FILTER(values(combineSales[IM Customer Code]),combineSales,x>=200))Or
Buying Customer =var x = CALCULATE(SUM('combineSales'[Value]),PARALLELPERIOD(LASTDATE('Calendar'[Date]),0,MONTH))
CALCULATE(countx(FILTER(values(combineSales[IM Customer Code]),combineSales,x>=200)),[IM Customer Code])- isyammilFrequent Visitor
Thanks for help, but your first method gave same result while second method return error cannot using COUNTX
- v-henryk-mstf
Hi isyammil ,
Need to count the Buying customer field instead of the IM Customer Code field. So try the following formula:
Buying Customer = VAR x = CALCULATE ( SUM ( 'combineSales'[Value] ), PARALLELPERIOD ( LASTDATE ( 'Calendar'[Date] ), 0, MONTH ) ) RETURN CALCULATE ( DISTINCTCOUNT ( combineSales[Buying Customer] ), FILTER ( combineSales, x >= 200 ) )If the problem is still not resolved, please provide detailed error information and let me know immediately. Looking forward to your reply.
Henry
