bilingual's avatar
bilingual
Icon for Helper V rankHelper V
3 years ago
Top 3 Minimum and Top 3Maximum values, how?
Hi i am used to dynamic filter in Excel, but if i want to create a matrix table with the following values( Price per unit) based on the filter:
TOP 3 Maximum price per unit
TOP 3 Minimum price per unit
Is there an easy way to do so?
  • bilingual , need to create 2 different matrix visual for top 3 and bottom 3 as only one top N filter can be applied to a visual at a time.
    • bilingual's avatar
      bilingual
      Thanks a lot, couldn find it, if i want to create a filter, with TOP and BOTTOM 3 bottom, can you help me? - The values are based on a measure.
      • ChiragGarg2512's avatar
        ChiragGarg2512
        Icon for Solution Sage rankSolution Sage
        bilingual Go to View Tab, there is an option for filters. Then in the filter pane click on the field which has to sorted for top 3 or bottom 3. Expand it and change Filter type to TOP N, select either top or Bottom and the number, also the value on which top/bottom N is being ranked.
