Mariollo's avatar
Mariollo
2 years ago
Toggle between absolute values and % - using field parameters
I have a table like below:
I would like to use field parameters to toggle between absolute and % values to have second view like below:
For first values I have simple DAX measure
Absolute = COUNT ( Table[product_id] )
How can I have % values?
  • Hi Mariollo
    You can remove the filter using the Calculate function
    Absolute % =
    Calculate( COUNT ( Table[product_id] ), AllSelected(Table[range_column]))
    • Mariollo's avatar
      Mariollo
      Thank you, this is also working 🙂
  • ajohnso2's avatar
    ajohnso2
    Icon for Solution Supplier rankSolution Supplier
    If you have access to the model you could create a static table via 'Enter Data'.
    Lets call the table 'Display Mask'
    Add a column and name it 'Display'
    Add a value 'Absolute'
    Add another value '%'
    Save and exit power query to apply the changes.
    You should have 2 measures already created (if not you should do this first)
    1 measure will hold the Absolute value
    the other measure in %
    You will then create a new measure, lets call it 'User Preference' and define it as below.
    User Preference =
    VAR _SelectedDisplay = SELECTEDVALUE('Display Mask'[Display],"Absolute") (Default selection will be abs if nothing selected)
    VAR _Abs = [Absolute Value]
    VAR _% = [% Value]
    SWITCH(
    TRUE(),
    _SelectedDisplay = "Absolute", _Abs,
    _SelectedDisplay = "%", _%
    N.B Be sure to drop the column from your new table into your report as a slicer
