Time difference between current output and previous output
- 4 years ago
Hi, Karthik12 ;
You could try it.
1.create a column
diff = var _last= CALCULATE(MAX('Table'[Time]),FILTER('Table',[Time]<EARLIER('Table'[Time])&&[Date]=EARLIER('Table'[Date]))) return DATEDIFF(_last,[Time],SECOND)2.set top 3:
If the above one can't help you get the desired result, please provide a simple and your expected result with backend logic and special examples.
Community Support Team _ Yalan Wu
Hi, Karthik12 ;
You could try it.
1.create a column
diff =
var _last=
2.set top 3:
- Karthik124 years ago
Post Patron
Hello v-yalanwu-msft Thank you so much for the support.
I have tried to attach my pbix file but couldn't find option.
So, attached as image.
I would like to get support for a time line graph for time intervals between latest time and previous time.
like below. Obvisiouly, first part time interval should be calculated as shift start time as indicated below.
Hope this data give some clarity to you. If not, any alternate way to send pbix file to you?
Thanks in advance for your kind support !
