Axel_hnk's avatar
Axel_hnk
4 years ago
SUMX Problem with Forecast % on Certain Level
Hi there,
I basically want to calculate a forecast for a current MTD Value for a product till the end of the month. The problem: Although I am using SUMX / VALUES the aggregation/totals are not considering that.
Due to uncertainties regarding past availablity I want to calculate the saisonality for the forecast on the combined level of Product_Category AND Product_Subcategory. A Product_Subcategory can be applied to multiple Product_Categories.
Example:
Product_Category_Product_Subcategory result:
Current month - previous year total sales: 1000
Current month - previous year MTD sales: 150
==> 15% saisononality percentage
Product result:
Current month - current year MTD value: 28
Forecast: 28 / 0.15 = 186.66
The forecast value is derived from a 3 year average of the previous years. The example shows the 1 year previous example calculation.
Percentage_Measure =
VAR MaxDate = MAX ( Date_Dax[Date] )
VAR EndOfMonthCurrent = MAX ( Date_Dax[Calendar EndOfMonth] )
VAR StartOfMonthPast1 = DATE ( YEAR ( MaxDate ) - 1, MONTH ( MaxDate ), 1 )
VAR EndOfMonthPast1 = EOMONTH ( StartOfMonthPast1, 0 )
VAR EndOfDatePast1 =
IF (
//Check if endofmonth selection - relevant for Feb 29/28
MaxDate = EndOfMonthCurrent,
//Calc the real end of month of the past year
EOMONTH (
DATE ( YEAR ( MaxDate ) - 1, MONTH ( MaxDate ), 1 ),
0
//use the given date
DATE ( YEAR ( MaxDate ) - 1, MONTH ( MaxDate ), DAY ( MaxDate ) )
//calculate the result for the whole month of the previous year
VAR VolumeEomPast1 =
SUM ( 'Sales'[Sales Value] ),
Date_Dax[Date] >= StartOfMonthPast1 && Date_Dax[Date] <= EndOfMonthPast1,
ALLEXCEPT (
Product_Table,
Product_Table[Product_Category_Product_Subcategory]
//calculate the result for the MTD value of the month of the previous year
VAR VolumeMtdPast1 =
Date_Dax[Date] >= StartOfMonthPast1 && Date_Dax[Date] <= EndOfDatePast1,
ALLEXCEPT (
Product_Table,
// calculate the % - in our example 15%
VAR VolumePercent1 = DIVIDE (VolumeMtdPast1, VolumeEomPast1)
Here is what I'd like to see (forecast calculated on Category_Subcategory and then summed up to Category) :
(The table looks a bit weird - the community forum of MS makes my tables always weird, although generated with the basic table tool)
Product CategoryProduct_Category& SubcategoryProductForecastSales ValuePercentage
Cat_A  112517516,5%
 Cat_ASubCat_A 100015015%
  Prod_1333,335015%
  Prod_25007515%
  Prod_3166,662515%
 Cat_ASubCat_B 1252520%
  Prod_4501020%
  Prod_5751520%
Cat_B  5009520%
 Cat_BSubCat_A 3004515%
  Prod_6133,332015%
  Prod_7166,662515%
 Cat_BSubCat_C 2005025%
  Prod_82005025%
When I apply the follwing formula:
Forecast_Measure =
VAR VolumeAmount = Sales_Volume_MTD_Measure
VAR AVG = Percentage_Measure // from above
DIVIDE(VolumeAmount, AVG)
I get this (not really astonishing) - calculation on top level with aggregated values - WRONG:
Cat_A  1060,617516,5%
  Prod_1333,335015%
  Prod_25007515%
  Prod_3166,662515%
  Prod_4501020%
  Prod_5751520%
Cat_B  4759520%
  Prod_6133,332015%
  Prod_7166,662515%
  Prod_82005025%
So I need to use SUMX. I tried this:
SUMX(
VALUES(Product_Table[Product_Category_Product_Subcategory]),
But I got a very wrong result on the ALL_Category level (roughly something like the forecast sum fo all Subcategories multiplied by the number (count) of existing (even without Sales_Value) Subcategories. When I filter out a blank Subcategory the result changes as well (decrease).
So I experimented with dozens of combination leading to either one of the results. It's like as SUMX is not doing it's job properly.
I hope I could make my situation clear and you guys have an idea where I am wrong.
Much appreciated, thanks!
1 Reply
  • v-kkf-msft's avatar
    v-kkf-msft
    Hi Axel_hnk ,
    Please try the following generic measures for calculating total value.
    Measure =
    SUMX ( VALUES ( 'Product_Table'[Product_Category& Subcategory] ), [Forecast_Measure] )
    Or
    Measure =
    SUMX (
        SUMMARIZE (
            'Product_Table',
            'Product_Table'[Product Category],
            'Product_Table'[Product_Category& Subcategory],
            "_Forecast", [Forecast_Measure]
        [_Forecast]
    If the problem is still not resolved, please provide detailed error information or the expected result you expect. Let me know immediately, looking forward to your reply.
    Winniz
