DTaraboletti's avatar
DTaraboletti
3 years ago
Strange Problem with Text Box Visual Display
Has anyone seen this?   As shown in the screen capture below, the three text boxes, which make up a portion of my report header, display grey rectangles at the right most edge of the object.   This problem is visible in Power BI Desktop and in published reports.
I've checked the border (and related) properties and see no reason for this.   I've provided screenshots of the property settings (for one of these text boxes) below for consideration.
Thanks in advance for your insight.
  • this measn its just too big to remove paddings , increase the height of the box or decrease font size
  • eliasayyy's avatar
    eliasayyy
    Icon for Memorable Member rankMemorable Member
  • Thanks for the quick response.  I am used to the way other MS products present this problem.  I reduced the padding and it works fine.
