Anonymous's avatar
2 years ago
Stange Cardinality problem
the steps :
replace empty lines with nothing: replace ' ' by ''.
delete duplicate lines
group them by the number of times a Serial Number appears :
I take only those that will appear once.
I do EXACTLY the same thing for my Dimension Table:
Except that when I import my tables into Power BI and link them in the “Model View” section, Power BI refuses to link the two tables in 1:1 ... even though I have Serial Numbers on both sides:
Inner join.
All other combinations don't work.
Thank you for your help!
Ps: I've been blocked for two days and I don't understand why it doesn't work
1 Reply
    Hi Anonymous ,
    Can you show me your sample data?
    I need to do some testing on your data to reproduce your problem.
    Dino Tao
