masplin
Power Participant
6 years agoSQL vs Power SQL joining of tables
I have inherited a Power BI model built by a guy who came form an SQL background whereas I come from an Excel background and very rudimenatary knowledge of SQL. I need to expand on some of the que...
houston39
6 years agoHi Mike,
Do you have access to SSMS? Also, retrieving the SQL embedded within power BI is not very difficult, one you step through it.
Check this out:
https://community.powerbi.com/t5/Desktop/Edit-Existing-SQL/td-p/48607
Then, see if you can run the query within SSMS - if you can I will assist you further.
G
