Anonymous's avatar
6 years ago
Split Column with multiple values in same column
Hi
I have a file with multiple columns, where each column can be one or more companies. Something like the following format:
Date              | Company1      | Company2
01-02-2019   | 1000               | 2000
...... (400 rows about)
Date              | Company 1    | Company 4
01-02-2018   | 1000               | 2000
I need to unpivot this, to something like this:
Date              |  Company       |  Amount
01-02-2018   | Company1      | 1000
01-02-2018   | Company2      | 2000
01-02-2018   | Company3      | 2000
01-02-2018   | Company4      | 2000
How can I achieve this? Is there any way?
BTW, This is an example of the file:
https://www.spensiones.cl/apps/valoresCuotaFondo/vcfAFPxls.php?aaaaini=2002&aaaafin=2019&tf=A&fecconf=20191130
Thanks!
    Right click on the date column and select Unpivot Other Columns.
    Please hit the "Accept as Solution" button if my post answered your question! If my post was helpful please consider giving it a "Thumbs Up."
      Hi
      Didn't work because doing that I've lost the relation between the companies and the amounts.
        I guess I'm unclear what you mean by the "relation between the companies and the amounts"
        You started with something like this, correct?:
        And you should have ended up with something like this:
        What do you need that this does not have?
