Split Column Help Needed
- 1 year ago
Hi scoutmedic ,
How about this solution in Power Query?
Before:After:
Here the code in Power Query M that you can paste into the advanced editor (if you do not know, how to exactly do this, please check out this quick walkthrough)
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("nVDLDoIwEPyVTU82wfLQk3f15CPBC7EcKlRthMXwiOjX2wImhIgHN5l2NzO7ne3xSLbyAUGW34hFXNu1Pcebm9SAwkrlRalPjBVeGCxrkd4TWYDCKKliueAoGJwbkWw5mPi7/dRxdDPHE4NCRhnGQ9YzbMSgvKq8R64rFQuMJGwEViIxIsXquja3YhA8dTS5Ll5taJ/dgxy72RwHc0hoje3pGVDwW5fji8L/m/Lyi8cflmYGFA7N15w/jiarLE+h7Z5TLenXJAzf", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Location = _t, #"Date Start" = _t, #"Deficency #" = _t, Finding = _t, Procedure = _t]), #"Added Finding" = Table.AddColumn(Source, "Finding_New", each Text.Trim(Text.AfterDelimiter([Finding], ") "))), #"Removed Columns" = Table.RemoveColumns(#"Added Finding",{"Finding"}), #"Split Column by Delimiter a." = Table.SplitColumn(#"Removed Columns", "Finding_New", Splitter.SplitTextByDelimiter("a. ", QuoteStyle.Csv), {"Finding", "Finding.a"}), #"Split Column by Delimiter b." = Table.SplitColumn(#"Split Column by Delimiter a.", "Finding.a", Splitter.SplitTextByDelimiter("b. ", QuoteStyle.Csv), {"Finding.a", "Finding.b"}), #"Split Column by Delimiter c." = Table.SplitColumn(#"Split Column by Delimiter b.", "Finding.b", Splitter.SplitTextByDelimiter("c. ", QuoteStyle.Csv), {"Finding.b", "Finding.c"}), #"Unpivoted Columns" = Table.UnpivotOtherColumns(#"Split Column by Delimiter c.", {"Location", "Date Start", "Deficency #", "Procedure"}, "Attribute", "Finding_new"), #"Added Procedure_new" = Table.AddColumn(#"Unpivoted Columns", "Procedure_new", each if Text.Contains([Finding_new], "(") and Text.Contains([Finding_new], ")") then Text.Middle( [Finding_new], Text.PositionOf([Finding_new], "(") + 1, Text.PositionOf([Finding_new], ")") - Text.PositionOf([Finding_new], "(") - 1 ) else null), #"Removed Other Columns" = Table.SelectColumns(#"Added Procedure_new",{"Location", "Date Start", "Deficency #", "Finding_new", "Procedure_new"}), #"Renamed Columns" = Table.RenameColumns(#"Removed Other Columns",{{"Finding_new", "Finding"}, {"Procedure_new", "Procedure"}}) in #"Renamed Columns"Note, the solution above is not very dynamic and you would need to add additional steps for the other alphabetical bullets like d., e., f. etc. This approach however has its limitations as soon as you get the to the letter i. Additionally, I made a few other assumption based on the data provided. My guts tell me that this approach won't take you all the way since your real data probably has some stuff in it which this solution does not take into consideration (yet). Still, it might get you closer 🙂
Hope this helps!
/Tom
https://www.tackytech.blog/
https://www.instagram.com/tackytechtom/
You can use following, just for testing create a blank query in power Query and put this within the advaned editor:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("tVDLDoIwEPyVTU+QYHnIybt48pHghQCHCkUbYTE8Ivr1toAJIerNTaadZrbT2YYh2fE7BGV1JQaxTdt0LMdVVEEHT1R1I1dMBZ4prDtW3HJeg8Akb1O+ipBRyPomPmig+fvDwrJsPcIThZonJaZz0ZFiQqG5iGqibVqRMkw4bBm2LJc9gnZdJzdBIXjIUlTy51Ay4vhWhKNvhDMTEhvfRnQUdPCHhH+Y8WO+H4GWCjoc+1/J3nk0r6wKGO67ynN6JnH8Ag==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Location = _t, #"Date Start" = _t, Deficency = _t, #"# Finding" = _t, Procedure = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Location", type text}, {"Date Start", type date}, {"Deficency", Int64.Type}, {"# Finding", type text}, {"Procedure", type text}}),
#"Split Column by Delimiter" = Table.ExpandListColumn(Table.TransformColumns(#"Changed Type", {{"# Finding", Splitter.SplitTextByDelimiter("#(lf)", QuoteStyle.Csv), let itemType = (type nullable text) meta [Serialized.Text = true] in type {itemType}}}), "# Finding"),
#"Changed Type1" = Table.TransformColumnTypes(#"Split Column by Delimiter",{{"# Finding", type text}}),
#"Removed Columns" = Table.RemoveColumns(#"Changed Type1",{"Procedure"}),
#"Split Column by Delimiter1" = Table.SplitColumn(#"Removed Columns", "# Finding", Splitter.SplitTextByDelimiter(" (", QuoteStyle.Csv), {"# Finding.1", "# Finding.2"}),
#"Changed Type2" = Table.TransformColumnTypes(#"Split Column by Delimiter1",{{"# Finding.1", type text}, {"# Finding.2", type text}}),
#"Replaced Value" = Table.ReplaceValue(#"Changed Type2",")","",Replacer.ReplaceText,{"# Finding.2"}),
#"Renamed Columns" = Table.RenameColumns(#"Replaced Value",{{"# Finding.2", "Procedure"}})
#"Renamed Columns"
What is does:
1) I use split by delimiter and use linefeed as delimiter (At the bottom of the dialog, expand Advanced options and check Split using special characters)
2) You can delete Procedure, as you can get this information from the new column by splitting by delimiter " ("
3) with the new column, you get replace ")" with nothing and you have your result
Oktay
Did I answer your question? Then please mark my post as the solution.
If I helped you, click on the Thumbs Up to give Kudos.
- scoutmedic1 year ago
OktayPamuk80 that might work, but I would need to keep the "i", "ii", and "iii" with their finding. Thoughts?
- OktayPamuk801 year ago
Responsive Resident
Yes, I didn't notice that one. However, glad Tom's solution worked out.
