5 years agoNot applicable
Showing the data through power BI using few SQL data tables
Hi, I'm just beginning using PowerBI and was wondering is it possible to show me the data I need. I have 2 SQL tables: So as you can see 1st table contains ALL UK companies with: Nu...
- Anonymous5 years ago
Anonymous this should be relatively simple.
Create a 1-many relationship between "All_Luton_Postcodes" and "BasicCompanyData" on the PostCode→RegAddress_PostCode.Then in the report, use a date slicer on "Incorporation Date" to filter by the dates desired, and a slicer on "LocalAuthrityName" to filter to the locale desired. Then add a table or matrix visual showing the desired information (CompanyNumber, IncorporationDate, Postal Code, etc.)
Hi Amine,
Please see attached pbix file
https://drive.google.com/file/d/1K8j441GvykLYUPK8AkZewKo3lfeFG0t4/view?usp=sharing
Kind regards
Kris
aj1973
5 years agoHi Anonymous Kris
Anonymous got it right but here is the file back to you
https://drive.google.com/file/d/1UMq40D_6FmZDBa1iw20u6Ssc9IKcl3ke/view?usp=sharing
