Anonymous's avatar
5 years ago
Showing the data through power BI using few SQL data tables
Hi,   I'm just beginning using PowerBI and was wondering is it possible to show me the data I need.   I have 2 SQL tables:   So as you can see 1st table contains ALL UK companies with: Nu...
    5 years ago
    Anonymous this should be relatively simple.
    Create a 1-many relationship between "All_Luton_Postcodes" and "BasicCompanyData" on the PostCode→RegAddress_PostCode.
    Then in the report, use a date slicer on "Incorporation Date" to filter by the dates desired, and a slicer on "LocalAuthrityName" to filter to the locale desired.  Then add a table or matrix visual showing the desired information (CompanyNumber, IncorporationDate, Postal Code, etc.)
