markefrody
Post Patron
3 years agoSetting Up Conditional Column Using Alpha Numeric ID
Hi Sirs, I am trying to create a "Classification" column wherein I try to classify the following alpha numeric: 1.) If ID starts with "MBKX" classify as "Private" 2.) If ID starts with "SMIX" ...
- 3 years ago
you can try this to create a measure
Measure = var _mbkx=IFERROR(find("MBKX",MAX('Table'[ID])),0) var _smix=IFERROR(find("SMIX",MAX('Table'[ID])),0) var _sub=len(SUBSTITUTE(MAX('Table'[ID]),"SMIX","")) return if(_mbkx>0,"Private",if(_smix>0&&_sub>=5,"Private","Public"))
ryan_mayu
3 years agonot sure if the real data is more complicated or not, maybe ID is something like SMIX12aab22
if not, I think you can combine the senario 3 and 4 because they return the same result
Column =
var _mbkx=IFERROR(find("MBKX",'Table'[ID]),0)
var _smix=IFERROR(find("SMIX",'Table'[ID]),0)
var _sub=len(SUBSTITUTE('Table'[ID],"SMIX",""))
- markefrody3 years ago
Post Patron
Hi ryan_mayu. Thank you for your assistance. I have tried using the DAX code but it seems not to work on my side. "IFERROR" seems to be not recognized. Did you create "New Measure" or "New Column" for the DAX?
By the way, I am using Storage Mode: Direct Query.- ryan_mayu3 years ago
