5 years agoNot applicable
Scatter Plot - Not Plotting Negative Values on X-Axis when using Numeric (Measure) Slider Filter
Hello - I have a customer data set, showing hourly profit rate by customer. I am representing the data using 3 main visuals, as well as other slicers. The 3 main visuals are (1) table, (2) scat...
Hi Anonymous ,
Sorry that I can't reproduce your problem. Could you please provide some sample data(exclude sensitive data) and visual setting in your report page in order to make troubleshooting? By the way, did you use any aggregate in scatter visual?
Community Support Team _ Rena Ruan
If this post helps, then please consider Accept it as the solution to help the other members find it more.
