ChristofferL
9 years agoFrequent Visitor
Rows missing in imported data from SQL-Connection (Power BI desktop)
Hi, When I import data from an SQL connection to the Data-model in Power BI Desktop the Data actually loaded to Power BI does not match data in my Query Editor Preview. It seems like some rows ar...
- 9 years ago
Hi thank you for the tip.
I managed to solve the issue and it indeed had to do with the column formating. The data format for the matching columns in the query merge were data type 'Any' for both columns.
For some reason most rows matched except a few rows apparently having a different format. I changed the format of the matching ID columns to 'Text' which solved the issue.
Thanks for your help.
Regards
Christoffer
Greg_Deckler
9 years agoPerhaps I am missing something but your first image seems to show that row in the dataset. ?
