Anonymous's avatar
6 years ago
Replacing blank values with values using M Script
Hi Experts
How would you edit the following M Script so (when Host Name [Computer] has entries, but there are blanks. where there are blanks I want to copy the value from "Name" )
  #"Replaced Value" = Table.ReplaceValue(#"Uppercased Text",each "Host Name [Computer]",each if "Host Name [Computer]" = "" then "Name" else "Host Name [Computer]",Replacer.ReplaceValue,{"Host Name [Computer]"}),
So as an example data is:
Host Name {Computer], Name
A1,A1.com
A2,A2.Com
A3,A3.com
,A4.com
, A5.com
, A6.com
A55, A55.com
To read
A1,A1.com
A2,A2.Com
A3,A3.com
A4.com,A4.com
A5.com, A5.com
A6.com, A6.com
A55, A55.com
  • camargos88's avatar
    camargos88
    Hi Anonymous ,
    You can try this code:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcjTScTTSc87PVYrVAfKMdRyN9ZKhPB1HEwRbwdEUmWMG5ziamoIkobKxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [#"A1,A1.com" = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"A1,A1.com", type text}}),
    #"Trimmed Text" = Table.TransformColumns(#"Changed Type",{{"A1,A1.com", Text.Trim, type text}}),
    #"Cleaned Text" = Table.TransformColumns(#"Trimmed Text",{{"A1,A1.com", Text.Clean, type text}}),
    #"Replaced Value" = Table.ReplaceValue(#"Cleaned Text"," ","",Replacer.ReplaceText,{"A1,A1.com"}),
    #"Added Custom" = Table.AddColumn(#"Replaced Value", "Custom", each if Text.Range([#"A1,A1.com"], 0,1) = "," then
    Text.Range([#"A1,A1.com"], 1,2) & [#"A1,A1.com"] else
    [#"A1,A1.com"])
    #"Added Custom"
    Ricardo
      Hi Expert
      Find attached sample data. I want the values in Column Names to populate into Column Host Name, when Host name is blank, using Mscript dynamically as the exel file is updated and also i still want to see all the rows in the table.
      link:https://www.dropbox.com/s/50syhbx3d8zk1sq/Sample_.pbix?dl=0
        camargos88
        Hi Anonymous ,
        Try this code:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("fZK9DoIwFEbfpTNNeqsDjLY0xligATQYw4JxcDDh/ScrxB+4ve3Yc04CX3q9sos/j/swjHB7jkKkLJmuDkYpB7pw/oq7pmZ9gtwMuxnhgkAuCMoF7ALlSuzKr+vZ6agc796HKwFcV7UJIkkj4LYtuKtzIozRuS1d+HtklM5tbs6RlqLA923xI1aRG/yh9QaLCv3lIozRwAaopWhgA9RSdLWB/qzTeLLT2ndWCkhFCv7dbiFgdtMkZVNZs7I3rO9f", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type text) meta [Serialized.Text = true]) in type table [#"Host Name" = _t, Name = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Host Name", type text}, {"Name", type text}}),
        #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each if [Host Name] is null or [Host Name] = "" then [Name] else [Host Name])
        #"Added Custom"
        Ricardo
