Replace column values using Uri.parts function
- 5 years ago
Hi awtahhan
The initial error you posted stated We cannot convert a value of type List to type Text. so I expected that your url column contains Lists somewhere like this
To avoid that error you can use try..otherwise when creating your Custom Column in Power Query like this
try Uri.Parts("http://contoso?a=" & [url])[Query][a] otherwise [url]which gives this result
Check my file above for the full code example.
Regards
Phil
Hi awtahhan
The column you're trying to decode contains Lists. Can you please supply some sample data to help me see what youu are working with. I need to know what is in those Lists.
Regards
Phil
- awtahhan5 years agoRegular Visitor
Hi PhilipTreacy
Thanks for your reply, please find below screenshot. The column does not hold full URL, it is only holding the encoded query parameter values. I want to decode those query parameter values.
