nguyenk172
4 years agoNew Member
Problem with Using SWITCH Function
I am trying to use switch to solve multiple IF statement. But this DAX formula gives me errror as shown below: Function 'SWITCH' does not support comparing values of type True/False with values of ...
- 4 years ago
Hi nguyenk172 ,
The formula you are using needs to be split and cannot be equal to one data and then directly equal to another value.
Refer the following sample ,as you provided:
Type1 = SWITCH ( TRUE (), ISBLANK ( PurchaseOrders[Agreement_KONNR] ) && PurchaseOrders[CreatedBy_ERNAM] = "BATCHJOB", "UC4BATCH" && PurchaseOrders[DocumentType_BSART] = "ZB", "Z1", "SPA", "Spot PO" )Get:
And after adjust:
Type = SWITCH ( TRUE (), ISBLANK ( PurchaseOrders[Agreement_KONNR] ) && ( PurchaseOrders[CreatedBy_ERNAM] = "BATCHJOB" || PurchaseOrders[CreatedBy_ERNAM] = "UC4BATCH" ) && ( PurchaseOrders[DocumentType_BSART] = "ZB" || PurchaseOrders[DocumentType_BSART] = "Z1" ), "SPA", "Spot PO" )Output:
And according your provided data,you need to adjust to the below:
Type1 = SWITCH ( TRUE (), ISBLANK ( PurchaseOrders[Agreement_KONNR] ) && (PurchaseOrders[CreatedBy_ERNAM] = "BATCHJOB"||PurchaseOrders[CreatedBy_ERNAM] = "UC4BATCH" ) && (PurchaseOrders[DocumentType_BSART] = "ZB"||PurchaseOrders[DocumentType_BSART]= "Z1") , "SPA", NOT ISBLANK ( PurchaseOrders[Agreement_KONNR] ) && (PurchaseOrders[CreatedBy_ERNAM] = "BATCHJOB"||PurchaseOrders[CreatedBy_ERNAM] = "UC4BATCH"), "Auto Calloff", NOT ISBLANK ( PurchaseOrders[Agreement_KONNR] ) && (NOT PurchaseOrders[CreatedBy_ERNAM] = "BATCHJOB"||NOT PurchaseOrders[CreatedBy_ERNAM] = "UC4BATCH"), "Buyer Intervention", "Spot PO" )Did I answer your question? Mark my post as a solution!
Best RegardsLucien
DarrenLau
4 years agoAdvocate I
Found your question interesting and I came up with the following. Hope it helps and at the very least, points you to the right direction to get your formula working.
Assign Status =
VAR _checkAgreement = IF ( MAX ( Purchases[AgreementID] ) = "-", TRUE(),FALSE())
VAR _checkCreated = OR ( MAX (Purchases[CreatedBy])="BATCHJOB", MAX(Purchases[CreatedBy])="UC4BATCH")
VAR _checkDocType = OR ( MAX (Purchases[DocumentType])="Z1", MAX(Purchases[DocumentType])="ZB")
VAR _status =
SWITCH(TRUE(),
_checkAgreement && _checkCreated && _checkDocType, "SPA",
_checkAgreement = FALSE() && _checkCreated, "Auto Calloff",
_checkAgreement = FALSE() && _checkCreated = FALSE(),"Buyer Intervention",
"Spot PO"
_status
Link to example PBIX for reference - SWITCH example
I had some trouble with the ISBLANK() function so I substituted "-" into the data as a check to save time.
Example table and results to check logic:-
