R script visual - "not writable directory" problem
- 7 years ago
Hi Boja,
From the error prompt, your current account doesn't have write permission this folder. Either you need to change the permissions for that folder, or change the R library location. If you want to install to the system library, you may run R or Rgui as administrator.
Reference:
"not writable" error when installing new packages on 3.2.0Best regards,
Yuliana Gu
Hi Boja,
Reference:
Best regards,
Yuliana Gu
- Boja7 years ago
Advocate II
Thanks, Yuliana!
It helped :)
