maygoyal
3 years agoNew Member
Question regarding power bi data source
Hi, I have a excel file on SharePoint. This file will be updated with power automate flow throughout the day with new row inserted each time. I have to use the data in excel file on sharepoint and s...
ppm1
Solution Sage
3 years agoYou can use the SharePoint Folder connector to bring in the data from your Excel file. And you can add a Refresh a Power BI Dataset to your existing flow; however, there are limits. If you have a Pro license only, it will be a max of 8/day. If the dataset is in a Workspace with a Premium capacity, it is much higher.
Pat
