Python is not running in Power BI
- 6 years ago
Hi pouyanebrahimi ,
When I first try to reproduce your problem, it works well. However, after I changed the Privacy levels of Python and the data source file, the same issue appeared.
Then, I tried these steps and it works well now.
1. Clear permissions of Python and the data source file.
2. Continue what you said.
If the issue is still there, please let me know.
Icey
Im still gettin the same error after changing the permission as suggested on solution. Any feedback please.
It should work!
Try to test you python-power conencting in a new power bi file.
I also tried just the dataset to hold = # 'dataset' holds the input data for this script
still not working.
im using python 3.8- pouyanebrahimi6 years ago
My python is 3.7. It should not be a problem though!
This is my suggestion, take screen shot of all steps (from importing data to error message) and share it here. Hopefully, we can find a solution.
Thanks, so basically, I have this survey value. Then running just the dataset as below, still getting the same error as indicated also as below. PS. im using 3.8 python, powerbi desktop, and a laptop company.
