TuanPham1999
7 years agoFrequent Visitor
Pull data from API using POST method in Power BI
Hi all, I'm a fresher in Power BI Desktop. my mission is extract data from given credentials include: ClientID, Password and Url. The credentials must be Base64 encoded for use in the POST /oauth2/to...
- 7 years ago
You may refer to the following post.
https://community.powerbi.com/t5/Desktop/Connect-to-a-Web-Service-sending-parameters/td-p/225510
6 years agoNot applicable
I found it not so easy to get data via POST so I am pasting here what I did in case this helps someone else in the future.
I created the following blank query:
= let
body = "The POST method body here",
Data= Web.Contents("https://yourusrlhere",[Content=Text.ToBinary(body),Headers=[#"Content-
Type"="application/json"]]),
DataRecord = Json.Document(Data),
Source=DataRecord
Source
- NateDogg4 years agoNew Member
I wanted to post a more complete/cleaner version of the above solution that contains multiple headers and shows how to convert the body to binary data for POST operations:
let url = "https://api.somevendor.com/api/", headers = [#"Content-Type" = "application/x-www-form-urlencoded", #"Accept" = "application/json"], postData = "Any sort of text data you want to post to the API", response = Web.Contents( url, [ Headers = headers, Content = Text.ToBinary(postData) ] ), jsonResponse = Json.Document(response) in jsonResponse - Markzolotoy5 years ago
Impactful Individual
What body = "The POST method body here", is for?
- i42 years agoFrequent Visitor
How can I insert a variable (dateTo) instead of the date, i.e. 2024-12-31, into parameter5?
let dateTo= DateTime.LocalNow(), body = "{""parameter1"":""xxx"",""parameter2"":""xxx"",""parameter3"":""xxx"",""parameter4"":""xxx"",""parameter5"":""2024-12-31""}", Data= Web.Contents("https://xxx",[Content=Text.ToBinary(body),Headers=[#"Content-Type"="application/json"]]), DataRecord = Json.Document(Data), Source=DataRecord in Source
